Sealing Windows
Posted: Oct 23rd, '19, 14:18
by Captain Decent
Now that the rain is back in the PNW (wasn’t gone long). I am seeing some water drips from the window frame. It’s mostly but not limited to the area where the rear of the curved window stops and the side windows begin. What’s the preferred sealant for this? I was considering 4200 but maybe that’s too aggressive. Any suggestions?
Re: Sealing Windows
Posted: Oct 23rd, '19, 20:12
Most of the members use Silkaflex. 4200 is too aggressive. The issue is that due to all the twisting they will start to eventually leak again.
Re: Sealing Windows
Posted: Oct 24th, '19, 23:30
by Stephan
I have been told that 4200 does not have good UV resilience and that 3M's 4000 is formulated with UV resistance. I believe there are similarly a multitude of Sikaflex compounds and believe they append the product number with "-UV" to indicate durability in sunlight.
Good luck,
Stephan
Re: Sealing Windows
Posted: Oct 25th, '19, 08:00
by Snipe
https://www.bostik.com/ Try this site I use this to direct glaze my windows in it’s a great product.
Re: Sealing Windows
Posted: Nov 4th, '19, 20:36
by Mack
Do you happen to recall which product you used?
I am tired of replacing the exterior rubber for my front windows. Now thinking i just need to find a good UV resistant glaze.
Re: Sealing Windows
Posted: Nov 7th, '19, 12:30
by Captain Decent
What exactly do you guys mean when you say “glaze”. When I look it up it appears to be synonymous with “caulk” or sealant.
Re: Sealing Windows
Posted: Nov 7th, '19, 23:23
