replacing gauges
Posted: Oct 5th, '19, 09:09
FINALLY, FINALLY, FINALLY My 28 FB is running. It was a long road with replacing oil sending units, oil pressure switch, rebuild on starboard transmission just to pull it part way out to turn the transmission pump 180 degrees for counter rotation but both engines fire up and sound beautiful. Now I want my gauges to read correctly. Does anyone know if the water temperature gauges are different for dual station set-up?
