31 project update/question
Posted: Oct 11th, '18, 09:53
by CappelloVince717
I have a 73 31 bertram I’m restoring. I fiberglassed the front windshield in and that project is almost done. I wrapped the boat for the winter so I can focus on the cabin. I have every bulkhead out. This week I’m going to redo the V Birth supports they are rotten. My question is I would like to do any bulkhead below the bildge in Coosa board. The front one that divide the v birth from main cabin I’m just going to use marine 3/4 the back ones that divide the engines Coosa. I can only find 1/2 Coosa at Barnegat light fiberglass. I was going to use 2 1/2 pieces laminated together equaling 1 inch. Any inlut would be great. Also for the skeleton of the cabin floor what wood are guys using I was going to use red oak but I’m open to suggestions. Thanks in advance sorry for any typos
Re: 31 project update/question
Posted: Oct 11th, '18, 16:16
i use a local distributor Dyna-Grout he is located in Deer Park, NY. he has 1/4,1/2,3/4, and 1 inch. i could find the phone number if you are interested he does not ship.
Posted: Oct 11th, '18, 18:14
by Snipe
Vince on my cockpit rebuild I have only used coosa I have laminated it together with good results. I am planning on using it in the cabin as well for as much as I can. I bought mine from Donovan marine only bad part if it is not in stock there is a ten sheet minimum. One day I will put a post up on here with pictures.
Posted: Oct 11th, '18, 22:33
Vince
I will see if I can find the invoice from when I d is mine back in 2008. I used 3/4 and had it shipped to me since I could not find it in NJ back then. I had ordered a 4x10 piece so we could use one piece.
Posted: Oct 12th, '18, 07:54
Do these bulkheads carry any structural loads? If not, the Coosa is probably overkill. Divinycell is readily available, cheaper and easy to work with.
http://www.diabgroup.com/en-GB/Products ... vinycell-H
Cam
Posted: Oct 14th, '18, 08:17
by Raybo Marine NY
Mesco/seacoast stock it and deliver in NJ. Check a local repair,marina,or Marine supply store if they can get it in for you. No shipping and you won’t have too drive far
I don’t have a Kellogg/land and sea boook here at home they may stock it too.
Personally If I had no local source I would rather pay freight then make a round trip from NJ to LI between fuel,tolls and traffic just not worth it. I’m sure a local shop can get it for you
Posted: Oct 18th, '18, 14:44
I deal with Mesco if you want to come to Staten Island.
