Barnacle Buster flush for Generator and AC System
Posted: Sep 17th, '18, 08:41
Would appreciate some feedback from the sandbox on this one.
I recently was trouble shooting my NextGen 3.5k generator. It was not flowing much water out the exhaust. The temp sensor failed as it heated up.
At first I thought it was a slight amount of calcium accumulated in the riser can. Pic below of a new riser can and elbow that I recently put in it's place. Also installed a new temp sensor.
The generator turned on but still did not push much water out the exhaust. I pulled a hose from the vented loop which then goes to the riser can. I got plenty of flow from the vented loop. But noticed in the bucket with the water from the tube, some calcium crud. Ran it till the crud stopped. Then I figured I better check the riser can again and the elbow fitting. See videos below. Heavy crud.
The support guy at NextGen says I should run Barnacle Buster through the system.
Has anyone had experience in treating their generator with Barnacle Buster? If so, I'd like to hear from you in how you plumbed it in there, as well as how long you let is sit in there? Do I take out the zinc or or any other tips?
My sea strainer for this system also feeds the Air Conditioner, which probably could use the same treatment.
Thank you.
https://youtu.be/2PyfQgNabqo
https://youtu.be/WzOhoFpbAwg
Here's a pic of the new riser can and elbow.
https://photos.app.goo.gl/AmvjVHMoxuWJyf79A
Thank you.
