Bonding Fasteners
Posted: May 11th, '18, 10:33
by Joseph Fikentscher
I cant seem to find any bronze bolts to fasten the larger zinc to the stern of the boat, trying to follow Capt Pat's advice. No one carries them in the Manasquan area. Will stainless work?
Re: Bonding Fasteners
Posted: May 11th, '18, 11:42
What size are you looking for?
Are you glassing them into the hull with the ends sticking out the stern?
https://www.mcmaster.com/#silicon-bronze-bolts/=1csoy9r
Posted: May 11th, '18, 12:09
Mike, basically yes. Was going to make the connection to the bonding strip, then use a sealant betweenwashers and nuts to the Hull with an extra nut for a spacer and then mount the zinc to the studs.
Posted: May 11th, '18, 13:38
That link has some 3/8" 16 bronze hex heads to 6" and 1/2" 13 to 4 inches.
Posted: May 11th, '18, 14:16
Thanks Mike. Ordered.
Posted: May 11th, '18, 21:18
Joe
For future reference the Bolt Depot has a great selection on stainless and silicon bronze. They are usually my go too for screws and bolts.
