1986 Bertram 28 factory galvanic isolator
Posted: Apr 1st, '18, 22:52
by Gigharbor28
Where should I be looking for this galvanic isolator if it is a factory install? The factory manual talks about it, but I haven't been able to locate it. Am I missing something really simple here? My shore power cord connects minship port side with a main A.C. breaker just aft in the port cockpit storage area with sliding doors. The boat is new to me. I am going through all the ground connections/bonding and cleaning all the connections. I just had the boat out of the water and there was some evidence of some electrolysis. I was going to purchase a new galvanic isolator and I just happened upon this info. in the manual. It would be nice if it is already installed.
Douglas
Re: 1986 Bertram 28 factory galvanic isolator
Posted: Apr 1st, '18, 23:49
Not sure if that was an option or standard install. It should be located between the main a.c. panel and the shore inlet.
Posted: Apr 4th, '18, 22:09
by Gigharbor28
Thanks Tony. I will investigate further this weekend
Posted: Apr 5th, '18, 12:25
by JeremyD
Mine is on a shelf behind the screwed in panel on the Port side cockpit. Just aft of the cabin. Mine is also a 1986
