Installation of Underwater lights questions.
Posted: Apr 24th, '07, 12:40
I am preparing to install the underwater lights in my transom, potentially this weekend.
I am curious about placement on the transom.
At this point they will go inside the stringers, about 28 inches apart, and about 6 inches up from the bottom of the boat. I am going to do a search of articles, because I know there were some great installation pictures some time ago, and I would love any input or advice at this point about things to look out for.
Many thanks in advance, and I am only a bit nervous drilling big holes in the boat! It will pass I know, but still...
Posted: Apr 24th, '07, 13:07
by neil
dug jp knows all about that stuff send him a pm neil
Posted: Apr 24th, '07, 13:25
by Capt. DQ
Dug,
Here's the way mine are done. They are just inside the stringers and the top of the lights are about the same height as the stringer.
DQ
http://s145.photobucket.com/albums/r210/dougq31/
Posted: Apr 24th, '07, 15:19
by ZeroCavity
I went with a single light right in the midle. Bruce has the boat now and I wil ask if he can take a photo and post it here.
Posted: Apr 24th, '07, 15:34
by dougl33
Doug,
What type/brand of lights did you wind up going with?
Posted: Apr 24th, '07, 16:09
Thanks for the feedback guys. I printed two threads from times past and think I am pretty well prepped. DQ, your info is perhaps the most valuable!!!!!! If you could snap a picture of what it looks like on the inside it would be great but not imperative by any means. And also, did you end up using a backing plate or just screwing the ring right in there with a good amount of bedding compound like 4200 or 5200?
I am thinking of using 5200, as I really don't want to have to take these out...ever. Certainly not accidentally!
Dougl33, I bought my lights through JP. Thanks JP!!!!
Posted: Apr 24th, '07, 16:21
Dug,
Once you get a layout and the holes drilled take a 6" DA and sand the high spots down on the inside, also sand the hull free of bottom paint. Use a liberal (its a hole in the bottom of your boat don't be cheap) amount of 5200 on the flange end and on the inside. Run the bronze locking ring down and tighten the locking bolts down. Clean up with denatured and run the wires home.
Remember to bond all the lights just like you would any thru hull fitting in the boat.
If you have questions shoot me a pm.
Posted: Apr 24th, '07, 17:21
by Capt. DQ
Dug,
JP nailed everything you where asking about, I will try to get you a picture shortly of the inside but give me a couple of days.
DQ
Posted: Apr 25th, '07, 09:33
Awesome guys. Thanks. That sounds like what I planned to do, so I am really excited and reasonably confident.
Thanks again.
Posted: Apr 25th, '07, 10:31
by dougl33
So what is the brand?
Posted: May 2nd, '07, 16:39
Aqua Lights.
