Paint choice for battery shelf?
Posted: Apr 21st, '07, 08:03
by STeveZ
Attached are pictures of the battery shelf that rests on the stringers and sits in the bilge (out of the water) between the engines. I took the batteries out and removed the shelf. The wood is solid and I want to repaint it before re-placing it. The entire finish is pretty rough and oil stained. My plan was sanding, followed by KILLZ followed by some kind of paint (what kind of paint?)? What say you?
Posted: Apr 21st, '07, 08:42
by Skipper Dick
Steve,
I have found that once clean, wood like that covers nicely with several coats of Bilge Coat. I use it in my bilge an on the battery shelf several years ago when I bought the boat and it is still as good as new. I also preceeded the bilge coat with dilute epoxy and let it soak in good and cure before I painted. It will never rot.
Dick
Posted: Apr 21st, '07, 08:53
Steve-
I did what Dick suggested this past winter for a battery shelf I made--epoxy diluted, then full strength, then white bilgekote. Came out real well.
John F.
Posted: Apr 21st, '07, 09:09
When I started rebuilding "Phoenix" I knew I was going to replace and add a lot of wooden stuff in the engine room. Rather than worrying about painting things I bought a gallon kit of West system epoxy, along with some thickener and some white pigment colorant. I just apply two coats of epoxy, slightly thickened.. each with a healthy slug of colorant. It seems to be ideal.. strong, durable, waterproof and white.
paint
Posted: Apr 21st, '07, 20:34
by thereheis
degrease let it dry wipe with denaturuated alchol and put 2-3 coats of epoxy with what ever color pigment you want .it will be there a long long time.just like ir guy said
phil
