Crossing the Gulf Stream with No Steering
Posted: May 15th, '16, 14:29
I thought I would post some info to the site with the thought that it may assist another person down the line.
Last Friday, May 13th we cast off from Hope Town, Bahamas en route to West End, Bahamas for the night.
Then cross to Lake Worth Inlet (Palm Beach, FL) on Saturday morning.
Although Friday the 13th is supposed to be un-lucky, I think we were actually quite lucky for a few reasons.
1. The hydraulic steering did not bust while we were underway. The boat was at rest.
2. We were in glassy calm waters of about 12' deep. Gin clear to dive under and set the rudders.
3. The winds were to be calm for two days.
4. I had "one bar" on my cell phone reception. That's like one call from jail. (I called Bruce with my last quarter)
The culprit was a bad ferrule inside a brass nut that connects the plastic tubing in the steering system.
The black plastic tubing backed out under too much pressure.
We are guessing too much pressure was supplied when I brought the boat down idle/neutral in order for "the Admiral" to pee off the transom.
In the past when I have brought the boat down to neutral the auto pilot loses it's mind. I forgot to set it into STANDBY. I won't forget to do that in the future.
When we tried to get going the boat spun in circles, then we heard a POP, the tube ejecting.
After trying to put the nut and bad ferrule back together for an hour or so and any other band aid idea to get it to stay on, it just would not stay under pressure when we tried to re-engage.
We are anchored under Great Sale Cay. Which we always have called No Man's Land. It's barren and pretty much the most remote spot on the journey to or from Abaco. My wife is now saying things like, "Why don't we have a gun on board? When we get back we are taking your dad's automatic rifle he offered us!"
I"m thinking if we don't fix this, we toss out the anchor and sleep here till we figure this out. That's not what she was thinking!
I had 5% battery on my cell phone and one "bar" (miracle out there actually)...So I used my one call on Bruce. He reminded me how to tie the rudders straight and "that'll get you home". I recalled reading this on the forum in the past. (Hint: Donate to this forum) In 5 minutes I had the rudders straight and we were off and running to West End. We got there by dinner time, rested and the next day we crossed the Gulf Stream to Florida.
We ran 100+ miles using the throttles as our method of steering. If you get rudders perfectly straight it's quite easy to operate. The toughest part was at Peanut Island. There are some jackasses there on the weekend. Slow and steady, and I got to finally use my big set of horns on one guy asleep at the helm.
Good part is, I could do this again quickly.
I plan to mark the cross bar between the rudders at dead center. This will keep me from having to dive overboard to look at the rudders in the future. If we were in big seas in the Gulf Stream that would not have been fun.
And I will carry some extra parts for the steering system now as well.
Pics below.
Thanks Bruce. Thanks Patrick for this site.
The nut and ferrule:
![Image](https://lh3.googleusercontent.com/-xJbw5xvQqpE/VzjE6z_tz2I/AAAAAAAAF7c/y0kdYg5QIec34sdIhKAy7iaCYGoT41vVACCo/s512/IMG_3927.JPG)
The plastic tube that backed out.
![Image](https://lh3.googleusercontent.com/-C2cul6-KYcA/VzjE6-q-8kI/AAAAAAAAF7c/qF4sQPE1c2kBOqwcF_E7loiMq82csD4PgCCo/s512/IMG_3929.JPG)
Ropes tied to 90 degree arm on each rudder. (Also tied one to the center as well later on)
![Image](https://lh3.googleusercontent.com/-yUK5lWsXIuM/VzjE64FA7iI/AAAAAAAAF7c/MNKA7At8iRYZSZU2A_kPYhuWqw4D2qqGACCo/s640/IMG_3930.JPG)
Back in FL at Grandpop's dock. Proud family/crew:
![Image](https://lh3.googleusercontent.com/-ofm-L6pSbk0/VzjE7RsqZKI/AAAAAAAAF7c/DoSQP6YhlBkJEWavOY54lefdVoTXi354ACCo/s640/IMG_3942.JPG)
First Leg of SPoT tracks:
![Image](https://lh3.googleusercontent.com/-VxJcO1WSImY/VzjLp9YoTvI/AAAAAAAAF70/vnAWgKXIe-0-z2dw6pmN9mU6NScvafEOQCCo/s1152/Spot%2BHope%2BTown%2Bto%2BFox%2BTown.PNG)
Second Leg of SPoT tracks:
![Image](https://lh3.googleusercontent.com/-o0dujTubf6A/VzjLp97c_2I/AAAAAAAAF7w/YKEhBvfpXBkpn1x58HthmMFUP1JCOEQ9wCCo/s1152/Spot%2BGreat%2BSale%2Bto%2BWest%2BEnd.PNG)
Third Leg of SPoT tracks:
![Image](https://lh3.googleusercontent.com/-eme5mEgvtNg/VzjLpneiypI/AAAAAAAAF7s/64Otnvrz0zknMUEsePf9AwP5kemyypGKACCo/s1152/Spot%2BWest%2BEnd%2Bto%2BPalm%2BBeach.PNG)
Pics below.
