ReJex on metal
Posted: Mar 22nd, '07, 09:56
A lot of you have asked me how ReJex works on metal. I'd never tried it until yesterday when I took the B31 bow chock that sits on my desk home to polish it - its bare bronze, never appears to have been chromed. It had gotten pretty ratty from folks pickiing it up, so polished with some metal polish and a buffing wheel back to mirror. Then applied a coat of ReJex, let it haze up, then polished with a cloth and let cure overnight. This morning I handled it and fingerprints just simply will not stick to it.
So I can now with confidence say its Magic in a Bottle for metal.
Posted: Mar 22nd, '07, 10:12
Vic-would you consider using it on an aluminum radar arch after cxing it? Walter
Posted: Mar 22nd, '07, 10:25
You would have to let the CX soak into the metal pores for a while, then wipe the surface clean with a solvent before using the ReJex.
Posted: Mar 22nd, '07, 12:15
by dougl33
UV,
Do you sell rejex as well?
I've been using it on the topsides of my 33 for the past 2 years and it works fantastic. There is a coal burning plant in my harbor. When I used wax, the black streaks would get behind the wax on warm days and would never come out.
Now, I put on 2 coats of Rejex every spring and the streaks wipe right off!
Posted: Mar 22nd, '07, 13:12
Doug, yes I do carry ReJex in the 12 oz. bottle for $10.02 plus shipping. I'm out of the 16 oz right now, but I've priced the 12 oz at the same per oz. as the 16. Just send me an email at VLR@RKKDLAW.COM with what you need and a ground shipping address.
Posted: Mar 27th, '07, 18:26
by Mitch
Vic, I'm working on this fishin boat that has an awful soot problem on the transom. I'm doing the hull with polyglow and was going to use rejex on the transom. Should I use rejex alone or over the polyglow on the transom? Thanks, Mitch
Posted: Mar 27th, '07, 18:44
Mitch,
You can apply the Rejex over just about anything, but nothing over the Rejex... I'd suggest to do your whole Polyglo project and then apply the rejex over it.
Posted: Mar 28th, '07, 20:41
by Mitch
Thank You Patrick
