Oil cooler fitting part identification with photos
Posted: Jun 22nd, '15, 17:51
Re: Oil cooler fitting part identification with photos
Posted: Jun 22nd, '15, 22:45
by Whaler1777
Its called a 90deg flare fitting to hose fitting.... Ive bought all my fittings from
http://maesco.com
Posted: Jun 23rd, '15, 12:40
NAPA had those but did not work. It is slightly different.
Posted: Jun 23rd, '15, 13:54
by Rocket
It is a compression fitting of some sort, looks almost like JIC. What is the female threaded in with, looks like it could be npt?. You could remove the whole assembly and replace it with something that is known.
A better option might be to take the fitting and hose to a hydraulic shop that sells Parker and makes their own hoses on site. They will have a very wide selection of fittings, on of which is bound to be compatible with yours.
Posted: Jun 23rd, '15, 14:26
Thanks guys. I did find the Parker site and some fittings that looked similar. I bit the bullet and ordered them direct from dealer since they were able to locate some. About 240 total for 4 lines with fittings. I still would like to know the technical name of the part. I would still like to make a spare one with weather connections. Sometimes the simple things get me.
Posted: Jun 24th, '15, 10:46
by Whaler1777
Jic to hose 90deg fitting.
Posted: Jun 24th, '15, 19:47
I was thinking JIC too based on some photos I found. None of them showed the fitting inside of the female nut though.
