Fuel Pump for gassers
Posted: Feb 24th, '07, 01:27
I want to share my recent fuel pump replacment/modification with you gasser guys and get your opinion. I have 454 Marine Power with Carter electric fuel pumps.
At the end of last summer one day I was fishing just off of Fort Morgan for Spanish. Up until that day I had never experienced a problem with my fuel pump.
I was going up current from a rig, shutting down my engines and drift fishing back past the rig then cranking up and doing the same thing all over again.
After a few times of doing this my starboard engine would crank, run for a few seconds then die. The fuel pump was not delivering fuel to the carb. I finally had to remove the fuel line from the carb and suck fuel thru the pump to "get it primed" then we ran for home. As long as I did not shut off the engine it would keep running just fine.
The port engine never faulted at all. The fuel tank vent was not obstructed and the filters was brand new.
Obviously I had to replace the fuel pump but a friend told me that he had noticed that fuel pumps were failing prematurely on the Marine Power engines as well as some of the Mercruiser engines.
His recommendation was to install a "Bypass Type" fuel pressure regulator in the system so that the pump could circulate unused fuel back to the tank thereby keeping the pump cool and extending its life.
I followed his recommendation, installed the regulator and a 3/8" return line back to the tank. I found that the fuel pump could pump 7 PSI but the engine would operate at WOT at 2-1/2 PSI so I set my regulators to 3-1/2 PSI and you would not believe how much fuel is being returned back to the tank. Now the entire fuel system stays cold.
So what do you guys think????
Harry Babb
Harry Babb
