B28 Diesel tank question
Posted: May 27th, '14, 10:02
I decided to clean my diesel tank. It is made of f/g with 3 riveted SS buffers that only leave an inch or so in the bottom for the diesel to flow.
As you can see in the first photo, the only access hole (initially) was the aftmost one, the one which is smaller than the rest. So to access the remaining 3 compartments we opened 3 more access holes.
![Image](http://i869.photobucket.com/albums/ab251/yet15/20140527_140437_zps0e60f404.jpg)
After cleaning as best I could with my pressure pistol, the situation in the 4 compartments is shown in the following 4 pics (from aft to fwd):
![Image](http://i869.photobucket.com/albums/ab251/yet15/20140527_140125_zps3dc9f550.jpg)
![Image](http://i869.photobucket.com/albums/ab251/yet15/20140527_140116_zps8b7fd705.jpg)
![Image](http://i869.photobucket.com/albums/ab251/yet15/20140527_140054_zps85d9417a.jpg)
![Image](http://i869.photobucket.com/albums/ab251/yet15/20140527_140107_zps9ab9b6df.jpg)
The water pistol cannot flex to reach the "ceiling" of the tank; the condition of the gelcoat(?) on the ceiling of one compartment is shown below:
![Image](http://i869.photobucket.com/albums/ab251/yet15/20140527_140144_zps09c85d9e.jpg)
The condition of the ceiling of the 3 compartments opened is shown in the extracted oval pieces, below:
![Image](http://i869.photobucket.com/albums/ab251/yet15/20140527_152901_zps674ef3ff.jpg)
As you can see, whatever the inner coating of the tank is (it looks like gelcoat that has been "cured" by time and diesel), it has flaked. With the pressure applied, all flakes that were either already broken off, as well as those that were ready to break, they were all cleaned and disposed off with the hand pump. There are some remnants that I plan to remove with the hoover so that in the end the tank will be clean and there will not be any loose flakes EXCEPT for the ceiling ones.
Question: What do I do next? Is the tank OK to fill up once it's clean and dry? Shall I bother about the ceiling? The only way to clean it is with the hoover's brush (the one for the furniture). There is a fine mesh at the diesel intake's end that would stop all debris from going through; anyway my filters never showed any trace of flakes so far.
Thank you in advance for your eventual input.
