Fiberglass hard top
Posted: May 14th, '14, 19:41
by JimmyG
OK I just finished the boat and hopefully she will be on her way to Forked river diesel tomorrow, next project a fiberglass top for my newly constructed aluminum hard top. I'm thinking of making a jig out of wood frames with luan and laminating it then gel coat, glass and then divynacel finished with another layer of glass and gel ...any input or pictures would be much appreciated a specially making wire runs and a dome to fit an electric teaser reel
Re: Fiberglass hard top
Posted: May 14th, '14, 20:41
by Thums Up
Jimmy,
You can use my hard top as a templet if you want. It is at Holiday Harbor(Forked river Diesel). It will save you a ton of time and money.
If interested let me know. I or John Lane can show where it is. It is plenty big enough 10.5x11.5'
Greg
Posted: May 15th, '14, 09:41
by JimmyG
Thums Up wrote:Jimmy,
Greg
Thanks I'll check it out this weekend
Posted: May 15th, '14, 12:53
by Thums Up
Cool, I should be there both days. Feel free to give me a ring. 610 306 1970 Greg
Posted: May 15th, '14, 18:53
by JimmyG
I may have looked at the wrong 31, is yours Fighting lady Yellow with teak transom?
Posted: May 15th, '14, 20:22
by Thums Up
Jimmy, i have a Ray Hunt Chris Craft back in the corner of the fenced in part. The yellow bertram is one Fiberglass Pat is doing the work on out front. I have like a 65 hatteras in front of me, help to hide me, unless they moved it.
Posted: May 15th, '14, 22:11
Jimmy
For Greg's boat you have to go into the fenced in area. Walk to the far left corner.
Posted: May 16th, '14, 11:12
Figure out the crown with your tower guy
The 31 changes from bow to stern slightly. Look at the rattle and hum thread that tower is the clone to mine ( built off the same jig)
There is a hard top at carvers for a project I'm working on for a friend it's just been skinned. So you can see the wire runs and what not
Posted: May 16th, '14, 17:34
by JimmyG
JP Dalik wrote:Figure out the crown with your tower guy
Thanks JP i'll look up where Carvers is, there is a yellow hull 31 near mine that has the same top, in fact it looks a lot like yours inside and out.
Posted: May 29th, '14, 19:42
by Marlin
For wire runs I have used plastic wire mold from electric supply houses, come with a lot of termination type attachments,it will easily hold a pair of 10 ga wires,leave a piece of et string or nylon line in for future pulls, make sure u have a plan and document the location of the chase for the future
