Awl grip over awl craft?
Posted: May 6th, '14, 07:18
by matt ciarpella
I need to paint on a boot strip but will awl grip adhere to awl craft
Thanks for any help. Matt
Re: Awl grip over awl craft?
Posted: May 6th, '14, 07:25
No problem Matt...
Posted: May 6th, '14, 08:20
by matt ciarpella
Capt. When is the best time to remove the tape?
Posted: May 6th, '14, 08:43
Matt,
Use
vinyl Fine Line tape only & pull while the paint is wet so that the paint edge lays down. Waiting for the paint to cure will result in a hard edge and the chance of chipping.
One trick I like to use is to double tape. Start by using 1/2" fine line tape then come back over it with standard blue painter's tape, leaving only about 1/16" of the fine line tape showing. That way when you pull the standard tape, most of the wet paint comes off with it. Then when you pull the fine line tape only a tiny amount of the wet paint remains.. You can use the same technique using
pre-taped masking paper also.
Posted: May 6th, '14, 15:32
by Gert van Leest
be adviced , that the paint dries faster on your boat than on the tape.. I do not want to know why :)
Posted: May 6th, '14, 18:11
by matt ciarpella
Thanks all
