Zero Cavity Pics
Zero Cavity Pics
Here is some eye candy of "Zero Cavity"
Did the final tweaking and sea trial today and I got 33.8 knots @ 3950 rpm with full fuel/240 gallons.
Instrument display pic is the Ray Marine e-120 interfaced to the Teleflex can buss system. I setup a full page display as an option for twin engine.
There is also a Teleflex display on a pull out panel on the bridge if you want to use the Ray unit on a full page GPS map or depth.
Additional is a Teleflex display in the stb engine room so you can monitor port and stb vitals while working on them without out having to jump to the bridge.
Both Teleflex displays are setup to show twin engine.
My part in this project was engine systems, controls, wiring and computers, startup, sea trials and tweaking various systems through out. Gen start up and load check.
Harry Babb
Post by Harry Babb »
Thats a great looking job............I'd be upset to see any fish blood or slime on that boat anywhere.
Simply beautiful
Harry Babb
In Memory of Vicroy
Post by In Memory of Vicroy »
Amazing job. Question - how does one get on the f.b.?
thereheis
zero cavity
Post by thereheis »
was wonderin the same ??
Uv,
Gerry's got the pilaster steps.
thuddddddd
Post by thuddddddd »
Awesome Bruce, just think what you could do with a worthy platform.............heck even a carver would be a upgrade
randall
Post by randall »
nice!!
JP Dalik
Post by JP Dalik »
well done!
Dave Kosh R.I.P.
Post by Dave Kosh R.I.P. »
Kudos Bruce. Super looking 31 and fast too... Dave K
Keep Fishing...
Capt. DQ
Post by Capt. DQ »
Damn,
All these nice looking 31's sure make me feel like I need to go back to the drawing board. Great Job!
DQ
"IN GOD WE TRUST"
nic
Post by nic »
Bruce,
Congratulations, beautiful job & result.
Could you pls provide the prop details?
Nic
ScottD
Post by ScottD »
Really nice, the soft gauges might take some getting used to though. Bruce, where is the main panel you show located? Great job!
ScottD
mike ohlstein
Post by mike ohlstein »
Nice clean job.
The panel looks like it's on the rope locker door. Is there an enclosure behind it?
Is this a FBC with the head removed, or a SF with a bulkhead added?
Where's the charger?
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
1973 FBC 1286 0273-315
Scott,
The panel is in the overhead, forward and center to the inside of the bridge facing. Regino Cabrera & crew did the vast majority of the work in Miami over about a 2 year span. The housing for the panel is glassed in & the overhead is raised about 3" over stock height.
Mike,
Gerry's "Zero Cavity" is a FBC & the head was moved to the V-bert configuration.
Charlie J
Post by Charlie J »
thats purdy, makes mine look like, well i cant say it
Post by Dug »
Wow. Beautiful!!!
scot
Post by scot »
Very nice indeed, inspiring. I'm going home and break out the sander.
Vince Luciani
Post by Vince Luciani »
Wow! It truly is inspiring. Being in the middle of my own project, I have a great appreciation for the amount of hard work and skills (and time & money) needed to complete a project like that.
Good job Bruce!
Amazing!!
capy
Post by capy »
That is one sweet looking boat.......
You should be very proud.
ianupton
Post by ianupton »
Gerry,
Nice looking boat! You should be proud.
How has the baby Bert been treating you?
Ian.
Nic,
The wheels are 19x23 four blade Nibrils.
Craig Mac
Post by Craig Mac »
Capt Pat,
HP, Trans ratio, and cruise speed would be helpful as well.
I am trying to compile a listing of repower results
In Memory Walter K
Post by In Memory Walter K »
Spectacular is the word. Wow! Walter
Post by Mikey »
Gulp! Sure makes me jealous. Fabulous work.
Congrats, Bruce and to the Cabrera gang.
Whew!
scot
Post by scot »
Bruce,
Are the cast, 90 degree, jacketed, water injection elbows Yanmar pieces?
Eddy G
Post by Eddy G »
Scot: The cast mixing elbows come from Yanmar with the engines and are normally attached directly to the turbo. Many applications require a custom made dry exhaust extension to gain the needed height above the waterline.
Eddy G.
Capt Dick Dean
Post by Capt Dick Dean »
Gerry, you make Dick Bertram smile.
A/K/A El Gaupo
Props also have a medium cup.
Yanmar 6LP/315hp, 2:1 gear boxes.
Cruise speed can be anything up to 200 off the top.
24knots@3000 rpm
29knots@3600 rpm
Elbows are factory part.
Pulled the boat this AM but not before taking Tony, my shop mate out for a ride.
He's missed my last two 31 refits and is the only guy I know with arms big enough to have a 46' Bertram tatoo'd on his bicept with great detail.
RussP
Post by RussP »
Bruce, I bet Tony was grinning ear to ear.
RussP
KAHUNA 1963 Sportfish
Hueso
Post by Hueso »
Capitan:
"Tremendo trabajo.........tienes que haber sacao'muelas como loco verdad?..........quedo preciosa.........ese barquito esta para correr todo el golfo y el este de Estados Unidos.....nuevamente felicitaciones......en relacion a la capota que le vayas a poner.......te recomiendo que vayas a la parte de fotos y busca la lancha No Respirar de Cesar Rivera......sleek, bajita y parece la original.....si quieres mas fotos de esa me avisas para que la veas en detalle......te lo recomiendo.........con esa capota se va a ver regia...."
TRANSLATION:
Great Job! and take a look at the fly bridge "roof"of the boat named No Respirar at the boat pics area....owner Cesar Rivera.....he designed it for his and it looks sleek......almost like the original one.....
Alot del trabajo se ha hecho y su hora de golpear con el pie detrás para una cerveza o dos.
Hueso
Post by Hueso »
Oh S#%^&! :shock: Bruce also knows Spanish......he the man, brooo!
GaryG
Post by GaryG »
Very nice!
What is her cruse speed & fuel consumption ?
Installing a tower ?
Gary
Gary,
Speeds are posted above.
No tower.
6LP's average 1 to 1.5 gal/mile at cruise.
ZeroCavity
Post by ZeroCavity »
Thanks to everybody for your nice coments ! Happy to share my project on this board for the past 2.5 years.
John Jackson
Post by John Jackson »
Beautiful! How did they do the front windows? Are they fiberglass frames?
I totally encased the original aluminum frames with ~3/16" of fiberglass layup. Each of the three sections were done individually leaving the designed slip joint for re-assembly.
Revels were made with PVC Foam Board & were glassed in so that window glass and acrylic corners would be glazed in from the inside. Both the glass and acrylic were glazed in before taking the units back to Cabrera in Miami for installation on the boat. They were fiberglassed in place, faired & gelcoated for a seamless installation.
Interior flange moldings were fabricated and fitted in fiberglass sheet stock.
For the blow by blow progression see: Glassing Over Bertram 31' Front Aluminum Window Frames
Would I do this again? Probably not... Way too much time and agrivation.
I think you were working on those when I stopped by your shop a couple of years ago. They did look complicated, but beautifully crafted.
Craig Mac
Post by Craig Mac »
Capt Pat,
How many hours did this take?
How hard would it be to fabricate in stainless? I know the Bertram Riva 25's had stainless frames.
John Jackson
Capt. Patrick:
Wow! This just proves that when there is a will there is a way! How the heck did you come up with the game plan for that project? How many hours did it take? Is there any chance of the fiberglass delaminating from the aluminum? Any interest in doing another one?
I like the way the slightly larger frames look on the boat. I have redone my whole boat, but the windows, while I doctored them up to a point of acceptability, are not on a par with the rest of the boat. I had a welder fill in the holes on the curved window outside rims and that part came out pretty good. I bolted it from the outside, and the screw heads don’t really offend me, although the clean t-bolt from the inside way does look much better. To disguise the condition of the windows on the Hound I had my canvas guy make a front windshield cover that is clear with white over the frames and from a little distance it makes it look like the frames are a little fatter and I think it improves the appearance a little. Plus it has stopped all the leaks. Maybe I will take a crack at doing what you did over the winter. I will try and take some pictures of my "quick fix" and send it to you.
PS. Are you going to Atlantic City?
Users browsing this forum: No registered users and 522 guests
