Ok, the wife and I spent the last two days removing all of the wiring, old engine bunks, degreasing, etc, in preparation for the new Cummins 4BT's.
Anyhow we found some rot on the forward and rear bulkheads, between the inside stringers.
The rot is about 8" wide and 12" high. Everything around is solid.
Whats the most sensible way to repair this? Cut out, replace and reglass the entire bulkhead? Sister a new composite bulkhead over the old?
Thanks.
http://www.flickr.com/photos/79792193@N02/6997062942
Engine Room Rot
- conchy joe
Engine Room Rot
Troy & Daria
Hypoluxo Point, FL
Hypoluxo Point, FL
Troy, My engine bulkheads were rotted all over top pt side and bottom like yours, but mine only had a lil bit of glass and lots of paint. The rear engine bulkhead is less of a structural bulkhead compared to the forward one. The engines are pushing forward and trying to go through your boat in that direction. Id cut out the rot and wet stuff, make a patch with coosa, making sure to cut water channels in the bottom of that patch to let the water run fore n aft, then Id add at least two layers of 1708, maybe some roving in between, then Id tab it back to the hull along the bottom after a healthy fillett of hight density/microfibers. Then work on sistering your engine bed stringers to push against that bulkhead, making sure ALL your tabbing is up to snuff...White glass in a bertram means fractured or weak connections, look for good DARK green glass..Green=Good..BH
- Harry Babb
Bob, I am the manager of Crescent Sail Yacht Club in Grosse Pointe Michigan. My boyfriend is a Bertram guy. I spend Sundays looking at all your posts. Because this is so important in our world. I was wondering would your wife like to text me while you all disscuss engines? Lots of wine tonight. But I do care about Bertram. I have bought Bertram rugs, Betram everything. My only goal is to meet Captain Patrick, my boyfriends HERO.
Engine room rot
Troy, where is the boat,with the bridge out I don't get to the west side as often but would love to see your project,went thru 20 plus sheets of coosa on my project,may be able to help
- conchy joe
Users browsing this forum: Google [Bot] and 110 guests
