Bermuda Project
Bermuda Project
Re: Bermuda Project
I am still working out how to post images so sorry for a little redundancy!
JJ
JJ
Re: Bermuda Project
Re: Bermuda Project
What a difference a day can make...I cannot wait to see the last day!
My brand-new mufflers and hoses didn't look that new when I got them. They look like the item to circle, that does not fit the picture.
Keep 'm coming,
Keep 'm coming,
Re: Bermuda Project
Hey you are right. I will see what size they are as I will be putting in a 6 inch system. If they are only 5 inch can they still work for that?
- franzmerenda
Re: Bermuda Project
Enjoy the journey!
Each time I suffer a stab pain due to credit card smoking, I tell myself: "it was worth it, it was worth it, it was worth it..."
...left engine raiser had better days...
Re: Bermuda Project
Those pics bring back memories. Are you doing all the work yourself?
Rick Ott
Carolina Reaper
Hull # Don't have a clue
Carolina Reaper
Re: Bermuda Project
I've done so many 31's those pics give me nightmares today.
Re: Bermuda Project
Yup. Fun but... not really kinda thing!
Re: Bermuda Project
So I did my B25 myself when I was 22 years younger. It was a slog then so I am leaving this one to a local crew -but keeping a close eye on them!!
Re: Bermuda Project
Jay Jay
They look like the 5 inchers in mine, but measure, since pictures make it difficult to determine size. I believe once you go above 270 HP in Cummins, you need to go to 6 inches.
Re: Bermuda Project
That first picture reminds me of a certain someone (who will remain nameless) who posted a picture of his project that had a tree growing out of the bilge. I can still remember Capt. Pat's reaction.
Re: Bermuda Project
Beat me with your rhythm stick, beat me....
Re: Bermuda Project
"Please sir may I have another!"
Re: Bermuda Project
Tony Meola wrote: ↑Jan 30th, '24, 22:35 Carl
What was to be a Hatteras Express became a Hatteras planter called The Tub.
It's incredible how big a 31 can get when working on it. I'd hate to imagine something bigger with a larger scope of work, having limited time and budget. Ugh...a few times I thought about bringing flowers down and turning mine into a planter.
Gas motors and by the looks I'd say at best they are 5". Not enough for Cummins at the hp you were talking about. Cummins does not like back pressure.
Re: Bermuda Project
Im fine, I just saw the pic of this poor 31 and thought of the time and money to just bring her to an ok condition...
Haha, you remember the song, right?
Re: Bermuda Project
Yannis, just heard that song yesterday!
https://www.youtube.com/watch?v=0WGVgfjnLqc
To JayJays...Congrats on the project!
Re: Bermuda Project
Guy's while I have your attention. I will be putting the Cabrera FG cockpit floor back in her but will be replacing the subfloor supports with Coosa. What do guys think the minimum thickness of Coosa is that I can get away with assuming I will be trying not to laminate most of it?
JJ
JJ
Re: Bermuda Project
Swing and a miss. It was a 31.Carl wrote: ↑Jan 31st, '24, 07:30 What was to be a Hatteras Express became a Hatteras planter called The Tub.
Re: Bermuda Project
Ricky,
Hit me, not beat me...you’re right!
But then again, it’s been what, 30, 40 years ago?
Phew...
Phew...
Re: Bermuda Project
EASY THERE TONY HAHA
Re: Bermuda Project
I see. What thickness Coosa did you use?
Re: Bermuda Project
3/4in on everything the stringers for the deck are 2 pieces of 3/4 in with 17/08 on both sides.
Jason
Re: Bermuda Project
Re: Bermuda Project
Yes it does bring back the memories!! All five years worth but worth every minute.
Jason
Re: Bermuda Project
Also, I checked where my rudders are and was surprised to see that they overhang the transom by a good couple of inches! I will be replacing with oversized from high tide and bringing them forward.
Bob Lico posted that the rake of the rudders changes bow attitude up and down. I think he said that trailing the lower edge aft a bit raised the bow and trailing it forward lowers the bow. First of al,l do I have this the right way round, and second how on earth does this work??
Could really use Bob's knowledge on this rebuild.
https://imgur.com/a/Lv3zMs7
JJ
JJ
- franzmerenda
Re: Bermuda Project
I ordered 3/4", 1" and 1 1/4" boards of Bluewater 26, but we found that 1 1/4" is too thick, compared to boat bottom stringers.jayjays1 wrote: ↑Jan 31st, '24, 17:46 Guy's while I have your attention. I will be putting the Cabrera FG cockpit floor back in her but will be replacing the subfloor supports with Coosa. What do guys think the minimum thickness of Coosa is that I can get away with assuming I will be trying not to laminate most of it?
JJ
Shipyard's Top Dog here, told me that everything thicker 3/4", is oversized as far as deck supporting structure; and he's aiming to screw laminated Coosa to stringers as it was with original plywood
Re: Bermuda Project
Ok thanks guys much appreciated!
Re: Bermuda Project
Those rudders look like they are in the right position. I don't think anyone would have moved them. You would probably be able to tell from the glass in the boat. If a repair was done or the rudders moved it probably will not match the factory glass.
Re: Bermuda Project
Yeah I don't think anyone moved them but they look to poke past the stern a couple inches. Isn't that bad ie aeration etc.? I Always thought that the whole of the rudder had to be under the hull to work properly?
JJ
JJ
Re: Bermuda Project
I don't think that they are back far enough to cause an issue.
Re: Bermuda Project
I’m with Tony I wouldn’t think those had been moved, but just for reference I have a stripped 1976 B31 Flybridge hull in my shop and I went by and measured the rudder flange tonight and that one was about 10 to 10.5 inches from the centerline of the rudder to the edge of the transom. The rudders are gone so I can’t speak to if they would overhang the transom. If that helps you any.
For comparison I also have a 1976 30’ Chris Craft Tournament Sportfish. it’s a similar hull to the B31 and the rudder centerline is about 7-8” from the transom on that boat. The original rudders were only long enough to reach the transom per the original Chris Craft design, but that seemed small to me so I had about 2.5” of plate welded to the bottom and trailing edge on those rudders when I redid the boat many years ago. So that 2.5 inches went past the transom and I didn’t recognize any negative effects, but I also had big trim tabs. The boat had a nice wake and steered well.
Some of the the Blackfin boats actually mount the rudder external to the boat, physically on the outside of the transom, so the entire rudder is behind the transom. I fished one of those once and don’t remember any issues.
Best of luck on your rebuild.
Re: Bermuda Project
There is a 28 in my yard with rudders installed and completely hanging behind the transom.
I'll ask the guy what effect this has on boat performance and will come back.
Re: Bermuda Project
Thanks guys. Very helpful as always.
JJ
JJ
Re: Bermuda Project
Hey I just replaced all my sub floor with coosa I used 3/4 around the edges and then laminated two 3/4 strips together to make the two middle beams.jayjays1 wrote: ↑Jan 31st, '24, 17:46 Guy's while I have your attention. I will be putting the Cabrera FG cockpit floor back in her but will be replacing the subfloor supports with Coosa. What do guys think the minimum thickness of Coosa is that I can get away with assuming I will be trying not to laminate most of it?
JJ
definitely nice and strong
Re: Bermuda Project
Update on Bermuda Project! Flybridge off and boat now stripped! Started putting in the Coosa but they were doing it wrong unfortunately!
https://imgur.com/kK4q5Hh
https://imgur.com/53eDg39
https://imgur.com/siOz9Sy
Re: Bermuda Project
Hey...what happened to the boat, it's all gone!
It does look better, although not much left there to look bad. lol
Re: Bermuda Project
Hey Ya, I like a clean slate. Gonna leave her as a Sedan. Gonna be sweet!!
- franzmerenda
Re: Bermuda Project
jayjays1 wrote: ↑Mar 14th, '24, 08:44 Update on Bermuda Project! Flybridge off and boat now stripped! Started putting in the Coosa but they were doing it wrong unfortunately!
This dream place alone is worth the project
Re: Bermuda Project
Thanks Fran. Only issue in Bermuda is that there isn't the large pool of knowledge on certain aspects of things.
JJ
JJ
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
