Opportunity to move some stuff around on the dash
Posted: May 11th, '23, 07:39
by JeremyD
So redoing the dash and instruments - Currently have the keys on top of the dash - but after realizing my keys were corroded and were always "on" (only the start function worked) I am thinking of relocating them to the panel under the dash... Any downside to doing that? I can put push button switches into the holes that have already been drilled for the key holes - thoughts?
OLD Dash
In progress:
Current status:
Re: Opportunity to move some stuff around on the dash
Posted: May 11th, '23, 20:42
Jeremy
My original factory set up did not use ignition key's. Flipped the breakers in the cabin on then went up top, fliped the switch to on and hit the start button.
When we repowered we put switches in and have both the ignition switches and the start buttons on the bulkhead for the cabinet under the dash. No issues and helps keep them dry if caught out in rain or rough weather.
Posted: May 12th, '23, 06:54
by JeremyD
Thanks for your response - That's what my thinking was too - especially with the keys that were on there corroded to the key holes (I couldn't remove the keys)
I've learned to ask- saves me from backtracking and redoing
Posted: May 12th, '23, 07:48
by Snipe
Mine only had push buttons on the original panel no keys. The new setup has keys and I put under the helm pod. Going under the dash is fine it’s pretty easy access. I put everything under the dash I possibly could even my VHF radios to keep it clean up too. My doors are split and can stay open when running.
Posted: May 12th, '23, 12:19
by Amberjack
JeremyD wrote: ↑May 11th, '23, 07:39
Depends on how long your legs are. When we repowered Amberjack we installed the keys and engine alarm switches under the dash and I noticed the first couple times out my knees were turning off the engine alarm switches. Now that I'm aware it doesn't seem to be an issue. You can also install a slender bar running between the two tabs to protect the the keys & switches.
Posted: May 15th, '23, 11:23
Mine was set up from the factory with the key switches under the overhang of the dash and the rubber push buttons on top of the dash. Seems to work fine. The down stairs station has them up on the dash.
Posted: May 15th, '23, 14:58
by JeremyD
Thanks Rawleigh - Was able to get the wheel on this weekend - starting to look like a boat again... [and I do plan on putting the keys under the overhang to protect them a little more from the Florida weather.]
