Eastwind 2022
Re: Eastwind 2022
Good news Pete glad you got a shakedown run in sounds like she ran good can’t wait to get together next summer somewhere. She is looking sharp.
Jason
Re: Eastwind 2022
Awesome Pete - great news - great results. The 330's move the boat along pretty well - can't imagine the 370's... Good for you
Re: Eastwind 2022
Congratulations. She looks great. Those are great numbers. It was a long wait but well worth it.
Re: Eastwind 2022
Was that the Eastwind that just blew by...
Stellar performance, you'll be grinning from ear to ear for a long time!
Congratulations on getting Eastwind to burn diesel, it was a long long road! Boating is so much nicer when you know the boats going to run...and boy does yours RUN! Maybe you should change the name to Grease Lightning
Re: Eastwind 2022
Congratulations, has to feel awesome.
Re: Eastwind 2022
Congratulations. Great results.
Re: Eastwind 2022
Congratulations Peter. Those numbers are great you have to be very happy.
Re: Eastwind 2022
This is a well-earned victory, Peter; congratulations. 30 knots at 85% of maximum RPM is fantastic.
Re: Eastwind 2022
Pete
Watching the video with you doing a test run, it seemed like the engines effortlessly increased speed as you moved the throttles forward.
must be a fantastic feeling after all the time you've put into it!!!!
- PeterPalmieri
Re: Eastwind 2022
Very interesting, I’ve spoke to a couple of guys here about it but without using my hands and lots of words it’s hard to describe. I’ll try….
So the boat used to as you hit the throttles, the bow would rise, the boat starts to push a lot water and eventually as the speed increase the bow would level out. Before getting into the 20s kt wise the boat would run a little too proud but eventually levels out.
With the 370s and not an aggressive acceleration the boat gets to 23 kts almost instantaneously without a change in the attitude. To get it to react the way it used to you have to be really slow and deliberate.
So it seems the torque just allows you to push the water out of the way and go instead of the old up and over. We got rid of the trim tabs and the guys doing the work kept asking if I’d want new ones. They dropped the boat in and ran it before I was down there and I think the first thing they said when they got back and called me was, the boat does not need trim tabs.
It’s pretty insane really, it’s hard to describe but you are 100% correct. Carl was nice enough to take me and my family on The Boat and we were completely satisfied with his 210s. Nice diesels good performance but it’s an entirely different animal now and I’m in shock.
Re: Eastwind 2022
how are you doing fuel burn wise? I am wondering if there is a case for being more efficient by having more HP and running it at a lower rpm?
Re: Eastwind 2022
Awesome! Eastwind becomes HOTwind!
1963 Bertram 25
1973 Boston Whaler 13 - sold!
Re: Eastwind 2022
It's that dam Italian influence.PeterPalmieri wrote: ↑Nov 13th, '23, 14:45 Very interesting, I’ve spoke to a couple of guys here about it but without using my hands and lots of words it’s hard to describe. I’ll try….
Funny, even with the 270 Cummins I found the boat had the same feeling. It just pushes the water out of the way and gets up and go. I usually push it up slowly also.
Re: Eastwind 2022
The no need for flaps, in what concerns the bow attitude, I understand. With so much power it is easier to obtain the attitude you wish faster and easier.
However, what I don't understand is why wouldn't the flaps be useful, or even necessary, in the case of two people deciding to move from port to starboard for any reason, while cruising. Wouldn't the boat change its left to right angle in such a case? Wouldn't a flaps’ input correct this imbalance?
- PeterPalmieri
Re: Eastwind 2022
So far I can only go by my rpm and speed reading vs the Cummins fuel consumption charts. But it seems really good doing the math. I’ll keep a journal next season for more real world numbers.
GPH per side
6.5 @ 2000
10 @ 2400
15.8 @ 2800
- PeterPalmieri
Re: Eastwind 2022
At this point it seems the extra weight and torque, the boat levels out. A couple guys moving around the cockpit doesn’t move the boat. Now a couple of overweight guys and some really heavy wind on the beam may change my mind in the future. Or if I put a massive fish on one side of the deck. As far as forward to back the tabs don’t seem necessary at allYannis wrote: ↑Nov 14th, '23, 05:05 The no need for flaps, in what concerns the bow attitude, I understand. With so much power it is easier to obtain the attitude you wish faster and easier.
Re: Eastwind 2022
Peter-
I think you're talking about a hole shot. The boat is at planning speed almost instantly as you throttle up.
You now have Big Wheels and tons of torque to turn them almost instantly on your boat. You're getting to speed and on plane before the boat has a chance to squat. Heck, your 370 motors are in my friend's forty-something-foot Carver stagecoach...and they push him at a good clip for a monstrosity. Your boat is like a potato chip for those motors.
Gas motors struggled to get into their power curve at higher rpms so the boat would squat a bit as speed came up, rpm came up and the boat would get up on plane and then level off. Diesel has gobs of low-end torque, no more struggle.
As to not being aggressive with throttles...keep in mind the stoke of your throttle gave 0 to maybe 400lbs of torque at 3400rpm with gas motors and now you're at 500lbs or torque at 1400rpm to over 730lbs around 1800rpm. Little increments are large jumps with the diesel compared to the gas motors.
My .02
Yes, that was a nice ride with your family, I enjoyed. That day keep in mind I was still in my Sea Trial get used to them mindset, I didn't like the back pressure or exhaust temp so I really babied them up to cruise and kept cruise at 2000 rpm for most of the day. I think on the way back I brought them up to 2100, she's just sloshing around at that speed. Since I made the new dumps, Tony Athens said my exhaust temps are in line, I do cruise her 22-2300 and that is about the point where she starts to get up out of the water a bit more and go. Still no comparison to what you running, but my 210s are pushing nicely.
My wife even commented that these motors just do not seem to struggle at all pushing boat on plane, it just goes.
For next year I sent my spare wheels out for some cup...we'll see what happens. Hopefully a knot or so at cruise and keep a relatively low trolling speed.
Or I have to figure out how to use trolling valve for bass n spoons.
Tabs I believe are beneficial for running 19knots n below. Once over that the need subsides.
My .02
Re: Eastwind 2022
In my experience once on a plane the weight of people moving about on Amberjack seems insignificant compared to the forces of water keeping the boat vertical. But if the Bimini is up the boat tends to sail. It feels as though the boat lifts a bit-it's certainly lighter to steer and it leans into the wind.PeterPalmieri wrote: ↑Nov 14th, '23, 06:50 At this point it seems the extra weight and torque, the boat levels out. A couple guys moving around the cockpit doesn’t move the boat. Now a couple of overweight guys and some really heavy wind on the beam may change my mind in the future. Or if I put a massive fish on one side of the deck. As far as forward to back the tabs don’t seem necessary at all
Peter, I've never been fortunate to put a massive fish on my deck but would gladly put up with the resulting list.
Doug Pratt
Bertram 31 Amberjack
FBC hull #315-820
FBC hull #315-820
- PeterPalmieri
Re: Eastwind 2022
After some additional adjustments, alignment etc the guys are reporting a top end of 36 kts and 23kts at 2100 RPMs which I think is where we will live most of the time.
Pretty darn happy at this point.
Re: Eastwind 2022
That is sweet. 23 knots at 2100 RPM's is perfect. I always found that the 31 really hits it stride at 24 to 25 knots depending on the boat weight. You might find yourself pushing her up a little.
Re: Eastwind 2022
Very Nice Peter, very Nice!
Scooting along at that clip will be great and I know will keep you happy.
What will be even better is knowing the boat is capable of making the trip to your destination and back without problems. And that is coming from someone who had reliable motors, the ethanol years aside.
- PeterPalmieri
Re: Eastwind 2022
Carl ironically the boat runs great on one motor now, something I had really become quite capable and now shouldn’t need.
But yes after many years to go out and know you are coming back is pretty awesome. Maybe a low bar but that was the need.
- scenarioL113
Re: Eastwind 2022
Pete,
I am happy you are finally seeing "it in the flesh" and hear the purr and feel the breeze coming at you! Wow your results are right were they should be.
23kts and "sipping fuel"
Think of that like "sipping clear" with the men that are no longer with us...
1971 28 Bertram
4BT Cummins
Frank
9-11-01 NEVER FORGET
4BT Cummins
Frank
Re: Eastwind 2022
...36 knots is one helluva breeze.
Re: Eastwind 2022
How does she feel at 36 knots? With the additional weight she should still feel like she is on rails.
- PeterPalmieri
Re: Eastwind 2022
I wasn’t on that run but sounds like she starts to get a little loose. I’m sure I’ll try it a few times next year.Tony Meola wrote: ↑Nov 21st, '23, 23:01 Peter
- PeterPalmieri
Re: Eastwind 2022
Game on that would be a dream.scenarioL113 wrote: ↑Nov 21st, '23, 09:08 Pete,
- PeterPalmieri
- PeterPalmieri
Re: Eastwind 2022
A couple little add ons in the cockpit to really finish things off.
- PeterPalmieri
Re: Eastwind 2022
No. She’s out in a tent in Shinnecock now
Re: Eastwind 2022
Peter, I have a similar need for gaffs, etc what are you using to pretty up the hole that allows the but ends to go into that panel?
I have an area under the gunnels and I was thinking 0 degree rod holders
https://photos.app.goo.gl/LJwkpPqbBtd66Hgy7
- PeterPalmieri
Re: Eastwind 2022
I’ll text you a picture it’s a simple black rubber cap with the center cut out like a pie or Star pattern.
- PeterPalmieri
Re: Eastwind 2022
Jason,
I’ve been texting with Carl. I want to make a trip over that way in the spring. Maybe we can get a bunch of local guys to make that run if he has some free dock space for 3-4 hours.
My nephew left for Puerto Rico for a SUNY maritime trip this morning. Had some picture coming out under the VZ. It didn’t look pretty today.
Pete
Pete
Re: Eastwind 2022
I’m sure we can rustle up a few spots for a visit
Re: Eastwind 2022
Yea we can definitely get some spots somewhere. It has been snotty for a couple days. Is he on the Empire State? The company I am working for rebuilt the dock I was up there for a couple months.
Jason
- PeterPalmieri
Re: Eastwind 2022
Yes that’s the new training ship. First trip for them, it wasn’t ready during the summer and they flew out to California and went to Hawaii instead.
- PeterPalmieri
Re: Eastwind 2022
Re: Eastwind 2022
Well done. She is looking good. Is she back in her slip yet?
- PeterPalmieri
Re: Eastwind 2022
Almost, the deck will be finished this week. Just finishing putting things back together. New headliner with an access hatch. Insulate the engine boxes, barrier coat the bottom and she’ll be ready when the weather changes for the better.Tony Meola wrote: ↑Jan 23rd, '24, 22:26 Peter
Re: Eastwind 2022
Very Nice, very nice Peter!
Shaping up to be a good year for boating and you're going to be doing it in Style!
Very Nice
Thanks for sharing!
Very Nice
Thanks for sharing!
Re: Eastwind 2022
Very well done! I'd like to do my cockpit like this. Keep posting more pics! Thanks.
Steve Marinak
Duchess - 1973 Sportfisherman
- PeterPalmieri
Re: Eastwind 2022
What we had to do was, Raybo built a belly band, which is also the gutter system. Then take the deck that had unfinished edges that were hidden under the side panels and add a finished edge. A lot of little details in routing things and such. But it’s going to be super functional and have that custom sportfish look when it’s done. I hope.
Users browsing this forum: No registered users and 85 guests
