Deck Supports
- Capt. Mac Creech
Deck Supports
Had some rot in the wood holding my fiberglass cockpit deck. Have removed so I have a template to go from. What is the best product to replace with.
Thanks, Mac
Thanks, Mac
Re: Deck Supports
Fiberglass structural pieces from Mcmaster Carr. Fiberglass C channel, etc.
Re: Deck Supports
I replaced with mahogany coated with West. I figured the original stuff lasted a good 40 years, and it was a lot easier for me to get 8' + mahogany than to get the stuff McMaster Carr. Just another idea.
Re: Deck Supports
i agree with John, and went the same route.
Eric Vincent
1974 31 FBC hull # 315-1442
- Pete Fallon
Re: Deck Supports
Capt Mac Creech,
I did my deck supports about 3 years ago.I used full board 5/4 White Oak then applied 6 coats of thinned epoxy, fastened them in with stainless steel 1/4-20 bolts. I used the same material for the rudder tables. My decks are 1" 80lb density PVC foam with glass over and under, they are light enough so I can lift them by myself, but strong enough to take a beating. The old deck support uprights have bronze 1/4-20 bolts that have a couple of bottom bolts that are impossible to get at because of the lip on the gas tank, I managed to notch that lip with a Dremel tool, make sure you just don't go too deep. I think it cost me around $300.00 by the time I was all done, for the wood, epoxy, saw blades and hardware total.
Re: Deck Supports
Fiberglass structural u-channel from Mcmaster.
Can't get much easier then order and have material delivered to your door.
Shot a bit of liquid wrench on the nuts then unscrewed the uprights, matched to size, cut and used old upright as a template for holes, drilled and slid new glass upright in place. When it was all done and fitted, I glassed to add extra strength.
The wood uprights did last 30+ years...but i know i'll never have to deal with "that" job again...at least not on this boat.
- Capt. Mac Creech
Re: Deck Supports
Thanks Guys
Re: Deck Supports
I used 1" Coosa and tabbed in the supports, easy to work with and will never rot
Re: Deck Supports
Here is a picture the red vertical supports are FRP bars from McMaster Carr http://blueh2ophotography.com/blueh2oph ... tos.html#0
- Capt. Mac Creech
Re: Deck Supports
Jimmy G what did you use for the horizontal support that the deck sits on? Is 1" coosa board rigid enough? Thanks
- Capt. Mac Creech
Re: Deck Supports
What is epoky thinned with and what ratio? Can polyester resin be thinned ? if so with what
Re: Deck Supports
See the post: http://bertram31.com/newbb/viewtopic.ph ... 562#p99876
I just finished my rocket launcher as described in that. I used 15% denatured alcohol.
BRUISER
BERG1552M76F-315
Bradley Tiller
BERG1552M76F-315
Bradley Tiller
Re: Deck Supports
I doubled the (Blue water 26) coosa to 2" at the top with thickened West epoxy, very ridged, easy to work with and will last foreverCapt. Mac Creech wrote:Jimmy G what did you use for the horizontal support that the deck sits on? Is 1" coosa board rigid enough? Thanks
- Capt. Mac Creech
Re: Deck Supports
Did you glass the entire support. Will Coosa work without glassing?
Thanks, Mac
Thanks, Mac
Re: Deck Supports
Capt Pat could tell you better but from the research I believe it will be a everlasting structure, it's hard to believe because it's so easy to work with and light weight ...I did not cover with glass just use west 610 and laminated the boards togetherCapt. Mac Creech wrote:Did you glass the entire support. Will Coosa work without glassing?
Thanks, Mac
Users browsing this forum: Google [Bot] and 276 guests
