Re: Barnacle Blok
Posted By: Rawleigh
Date: Sunday, 4 December 2005, at 10:04 a.m.
In Response To: Barnacle Blok (Sean Burlingham)
Soory Sean, I had computer problems. Yes Barnacle Block is unfortunately out of business. I had good results with their product. Met the Musselbuster rep in Miami last show and had long discussions about it with him. Turns out he used to work for Barnacle Block, but theirs is a completely different process. I talked to him at length again in May about doing my props as a Ches. Bay test boat, but because of timing problems on my haulout I could not send them away for that long. I will do it next year. It is a proprietary hightemp powdercoating process that they use. There are some problems if you used STP on the props as it causes outgasing on the baking process, but otherwise sounds like a good solution to the fouling problem. I've tried everything else, and these coatings are the only solution if you aren't able to go out in the boat every weekend. Rawleigh
Barnacle Blok
Sean Burlingham -- Friday, 2 December 2005, at 3:50 a.m.
Mussel Buster *LINK*
Sean Burlingham -- Friday, 2 December 2005, at 5:03 a.m.
Re: Mussel Buster
Capt Partick McCrary -- Saturday, 3 December 2005, at 4:42 a.m.
Re: Mussel Buster
Sean Burlingham -- Saturday, 3 December 2005, at 7:51 p.m.
Re: Barnacle Blok
Mikey -- Friday, 2 December 2005, at 5:32 p.m.
Re: Barnacle Blok
Ken -- Friday, 2 December 2005, at 11:04 p.m.
Re: Barnacle Blok
Walter Kaprielian -- Saturday, 3 December 2005, at 4:23 p.m.
Tempo
Sean Burlingham -- Saturday, 3 December 2005, at 8:02 p.m.
Re: Tempo
Harv -- Saturday, 3 December 2005, at 9:14 p.m.
Re: Tempo
Walter Kaprielian -- Saturday, 3 December 2005, at 10:13 p.m.
Re: Barnacle Blok
Rawleigh -- Sunday, 4 December 2005, at 10:04 a.m.
Re: Barnacle Blok
Sean Burlingham -- Sunday, 4 December 2005, at 12:17 p.m.
Re: Barnacle Blok
Walter Kaprielian -- Sunday, 4 December 2005, at 12:36 p.m.
